Reply To: I realize this may be a silly question but I don't really understand the difference between changing the size of the spot …
Forum Archive I realize this may be a silly question but I don't really understand the difference between changing the size of the spot … Reply To: I realize this may be a silly question but I don't really understand the difference between changing the size of the spot …
#22002
Thiago Menezes
    I see it like a lantern ray. If you increase the “size”, that lantern will shine over a bigger area, but the light itself will get scattered, weaker. Now if you point that weak light to a cone with a 2 holes and make it come trough that cone, a bigger or smaller cone will have different effects.
    Now if you turn that scattered ray into a thin, “dense ray of light and if you point that to the same cone, you get a lot more of light trough that cone. And the size of the cone also impacts.
