Hello Edward.
Can you share a little bit more context. Where did you put the new leaf? How are you trying to apply the colors? Can you share a screenshot of your material?
Remember Kent used the sampling tree addon and added the leaf he modeled. So if you created a new leaf after the tree was made, you’re going to have to replace the leafs manually I think. Or you could try the addon from a fresh new tree and select your new leaf.
If you don’t want to generate a new tree, maybe you can try selecting the leafs you already have and change their object data to use your new leaf data and material. Tell me if you need help with changing an objects data. It’s actually simple enough.
