This course is designed to use Eevee rather than Cycles.
Using rendered viewport shading with Cycles is good for viewing a single image or frame, but not viewing an animation.
If you are using Cycles for a project then material preview mode will play the animation without the blur, this mode essentially uses Eevee for the viewport even when Cycles is selected.
