Here’s more of what I meant by adding a color ramp… the purpose of the ramp is to allow control of the mask, so it would go between the generation of the mask and whatever factor it’s going to affect, allowing you to take the black and white and “crush” the values so that it has higher or sharper contrast. If you place it after the color mix, all you’re doing is changing whatever you set the colors to in the mix to a black and white.
