Reply To: I didn't like Melvin's leg, so I cut it off, and tried to reconnect the faces in edit mode which created a geometric night…
Forum Archive I didn't like Melvin's leg, so I cut it off, and tried to reconnect the faces in edit mode which created a geometric night… Reply To: I didn't like Melvin's leg, so I cut it off, and tried to reconnect the faces in edit mode which created a geometric night…
#23869
John Porter
    Kent, I posted the file as you suggested. I left sculpt mode and went into object edit mode; then switched to wire-frame and used a box selection on melvin’s leg; then deleted edges. This created a hole in Melvin’s leg through which I could see all the way up to his head. Nothing in Dyntopo seemed to close the hole.
