Forum Archive › i didnt leave pivot point in the same spot › Reply To: i didnt leave pivot point in the same spot
You can select the hinges in Edit Mode, place your Cursor there, like above and then in Object Mode go to Object > Set Origin > Origin to 3D Cursor.
(You said Pivot Point and the 3D Cursor can be the Pivot Point, but you probably meant the Origin…)
