Reply To: I can't texture paint with the wireframe lines visible. The only way I can see the lines is if none of the mesh is selecte…
Forum Archive I can't texture paint with the wireframe lines visible. The only way I can see the lines is if none of the mesh is selecte… Reply To: I can't texture paint with the wireframe lines visible. The only way I can see the lines is if none of the mesh is selecte…
#22861
David Frazier
    Unfortunately, there’s no solution for this problem. Which is why Texture Paint sucks so bad now!
