Reply To: I can’t see the change on “plane” when I switch to object mode!
Forum Archive I can’t see the change on “plane” when I switch to object mode! Reply To: I can’t see the change on “plane” when I switch to object mode!
#77199
    Hello Vladimir. Did you solved you problem like Erayvaz, the original questions poster, solved his also? It was just a matter that the speak was underneath the face. Or are you still having trouble?
