Reply To: I can't add keyframes in the Graph Editor. It simply doesn't do anything after I hit "Only selected channels". It does add…
Forum Archive I can't add keyframes in the Graph Editor. It simply doesn't do anything after I hit "Only selected channels". It does add… Reply To: I can't add keyframes in the Graph Editor. It simply doesn't do anything after I hit "Only selected channels". It does add…
#24039
Carkoon
    I went back to the Keyframe Preferences lesson and saw that under Keyframing I had “Only insert needed” enabled. After disabling it, it worked. Thanks.
    Another small problem: After I added the keyframes I don’t see those small black squares like in the video. The KFs are there and I can select them just fine. It’s just a bit hard to click on the right location.
