Reply To: I am using RMB to select, how do I call up the context menu in this case?
Forum Archive I am using RMB to select, how do I call up the context menu in this case? Reply To: I am using RMB to select, how do I call up the context menu in this case?
#76051
    @j.a.g.
    (Great that you are using RMB to select!)
    The shortcut SHIFT+S gives you this Pie Menu:
    You can then enter the number, or (faster) move the mouse pointer in the direction of the option you want.
    Like Omar said, if you want to use n to get to snap, you first need to open the Object dropdown menu.
    Can I ask what Blender Version you are using? (I can’t remember when they used parenthesis to denote the shortcut letter inside the menus instead of underlining.)
