Reply To: How to “scale” without changing size?
Forum Archive How to “scale” without changing size? Reply To: How to “scale” without changing size?
#79025
    Hi Parker,
    If the triangles are separate Objects, you can enable the Option to Only affect Location when Scaling:
    This Option is only available when in Object Mode.
    When your triangles are part of the console Mesh, you can Select them in Edit Mode and press P > Separate > Selection and then switch to Object Mode.
    See also lesson 8 in the Blender Basics course:
    https://cgcookie.com/lessons/edit-mode-and-object-origins
