Hi Khalid.
Ctrl F11 is shortcut to play back the animation that is set in the output.
Ctrl F12 will render the animation from the active camera. But if you wanted to render the viewport (rather than the camera), then go to the view menu > Render Animation (in the viewport that you want to render)
I hope that helps.
