That trick is to use sparingly, only on flat surfaces that don’t deform. You can leave the triangles it creates there, since they wont cause a problem is the surface is flat. In the end we must choose, or too many loops going all around creating tons of unnecessary geometry, or a triangle or two. You can also convert the triangle into a diamond quad junction like Martin did.
