Reply To: how to increase resolution of hdri?
Forum Archive how to increase resolution of hdri? Reply To: how to increase resolution of hdri?
#37600
Thibaut Bourbon
    You can’t change the resolution of a given HDR image, you’re stuck with its inherent resolution. Try looking for a higher res image (1k, 2k, 4k…). Often HDR come in different resolution to save memory, if you look where you got yourself that one you may find it on a higher res. Otherwise a solid HDR database is http://www.hdrihaven.com
    Good luck!
