Reply To: How to disable arcs in bezier curves
Forum Archive How to disable arcs in bezier curves Reply To: How to disable arcs in bezier curves
#80615
    I think you may need an extra key frame at the end. So you make the X curve as straight as possible to avoid the ball curving, use that extra keyframe for holding it and then bend the curve when it hits the ground. Kinda hard to explain by text, I don’t know how Wayne does this. Maybe you can upload the file so we can tweak it a bit?
