Hi, I don’t know if this would work. When you animate make all the key interpolation constant. You will have to mess around with the timing to get the right effect. Each key frame will be one of the pages and the frames between the keyframes are the time it takes the pages to flip. The constant interpolation should give the jump in the action. This is the blocking phase in animation. I hope this made sense, good luck.
