Reply To: How to clear normal map seams in render
Forum Archive How to clear normal map seams in render Reply To: How to clear normal map seams in render
#59945
artisticanarky
    So what could cause that color space issue you mentioned? Could it be the file type or too much layering? I tried the bump map and it did make the seams a lot less noticeable unless I get up close. But I would still like the angle data from a normal map on the shoes that aren’t show here. What is the best way to avoid these normal map seams when creating a texture, because this isn’t the only model I have had this issue?
