Forum Archive › How to add the lights to the grease pencil object for saving in the asset libary? › Reply To: How to add the lights to the grease pencil object for saving in the asset libary?
You use library overrides if you’re using linked. If you’re using append the. You just make instances real(Ctrl+a). Then you can edit it. Note: not everything is editable when using library overrides.
