Reply To: How exactly do I change the size of something in Object mode, like if I only wanted to make a primative smaller from one side, without going into edit mode?
Forum Archive How exactly do I change the size of something in Object mode, like if I only wanted to make a primative smaller from one side, without going into edit mode? Reply To: How exactly do I change the size of something in Object mode, like if I only wanted to make a primative smaller from one side, without going into edit mode?
#26562
Jonathan Lampel
    Make only one side smaller? I suppose you could use the Simple Deform modifier on Bend, but first I’d try to block out a similar shape without using anything fancy. It’s OK if it doesn’t look exactly right since the point is just to get used to object mode tools and blocking things out.
