Reply To: How do you overlap/combine animations?
Forum Archive How do you overlap/combine animations? Reply To: How do you overlap/combine animations?
#96278
Dwayne Savage
    That is commonly done in the NLA Editor.(NonLinear Animation).  If the bones/objects don’t have same keyframe then blending should be easy. If the they have matching keyframed pieces like both move the hip bone for example then by default the higher track replaces the lower track. In the N-panel(AKA the sidebar), you can change the blending to something other then replace. I’ve only used the combine. You can also use the animation influence on each track to determine the amount of influence each track has on a rig/object. Just be aware that that affect all keyframes not just the ones that are shared.
