The only thing I can think of why that would happen is if you have fog enabled in your lighting settings or through post processing. Fog by default is usually grayish or white in color and could cause that effect on far off objects. If you are positive you don’t have fog enabled, then post a screenshot of what you’re seeing and I’ll do my best to help you out from there.
