Reply To: How do I get from the first video to the second?
Forum Archive How do I get from the first video to the second? Reply To: How do I get from the first video to the second?
#27707
Jonathan Lampel
    Hey @dutzi , I believe I just had the other objects hidden (select the wheels, Ctrl+I to invert selection, H to hide) so that we could focus on the wheels, but the operations can still be performed with the rest of the truck visible as well. You can also use the eye icon in the outliner or select the wheels and hit / on the numberpad to go into local view.
    I assigned the materials through the material tab in the properties editor. If you need a quick refresher on materials, I’d recommend checking out our fundamentals course: https://cgcookie.com/course/shading-fundamentals-in-cycles
    An even faster way to do that though is to select all the objects that you want to be the same material, select the object that has the material you want to be copied to all the others in order to make it the active object, and choose Copy Material to Others in the dropdown next to the + and – buttons in the material properties.
    Hope that helps; happy texturing!
