Reply To: how do i fix the quirk about the button size not returning to its normal size ?
Forum Archive how do i fix the quirk about the button size not returning to its normal size ? Reply To: how do i fix the quirk about the button size not returning to its normal size ?
#25529
Jonathan Gonzalez
    Did you set the “navigation” settings on the button component to “none”? There used to be a weird issue in Unity where if you hovered over buttons that used animations it would get stuck in that state and start looping and it was due to how Unity thought you were navigating through the buttons. Using the normal state animation should be fine, but I would check the navigation setting first.
