Reply To: How do I enable the lines in UV editor?
Forum Archive How do I enable the lines in UV editor? Reply To: How do I enable the lines in UV editor?
#56157
    @moffale When you’re in texture paint mode for a selected object, make sure you’re using the Image Editor in Paint mode. The setting to enable/disable the UV overlay is “Display Texture Paint UVs”:
    Keep in mind that this setting should be enabled by default and visible whenever using the Texture Paint UI workspace.
