Reply To: How can I animate the 1st cloud?
Forum Archive How can I animate the 1st cloud? Reply To: How can I animate the 1st cloud?
#55560
    Spikey is right about animating the cube object itself. Honestly with procedural shaders the sky is the limit in terms of animation options (pun intended 😁). Animating the object + node values will produce tons of various motions within the cloud.
    A good way to test animation options is to slide node values. Sliding them gives dynamic results in the viewport and if you like the effect, add keyframes.
