Reply To: How are you snapping the vertices to the end of the bounding box when the snap button is not pressed?
Forum Archive How are you snapping the vertices to the end of the bounding box when the snap button is not pressed? Reply To: How are you snapping the vertices to the end of the bounding box when the snap button is not pressed?
#68747
    Hi Jeff, you can toggle snapping on/off by holding CTRL; this means that when you have the snapping ‘magnet’ on (highlighted) it always snap, unles you hold CTRL and if the snapping magnet is off, you only snap when you hold the CTRL button.
