Reply To: Hooking bezier curve to armature causing pinching?
Forum Archive Hooking bezier curve to armature causing pinching? Reply To: Hooking bezier curve to armature causing pinching?
#97695
    Hi Kimberly,
    In your file, Select the Curve, switch to Edit Mode, Select all, so you’.ve got this
    then press V > Set Handle Type > Automatic, to get this:
    I haven’t watched that video, btw. but I guess it must be something like this.
