Reply To: Hi, I've noticed that on Blender 2.75, the effect of using the inflate brush (to add resolution to the topology) is diffe…
Forum Archive Hi, I've noticed that on Blender 2.75, the effect of using the inflate brush (to add resolution to the topology) is diffe… Reply To: Hi, I've noticed that on Blender 2.75, the effect of using the inflate brush (to add resolution to the topology) is diffe…
#22796
    If these criteria are met, inflate should generate new topology as it sculpts:
    • Dyntopo is enabled
    • Mode is set to “subdivide collapse”
    • Strength of the brush is greater than 0.
    • Mesh is selected when in sculpt mode.
    @mleonard17 Can you verify that all of those are true and if the issue persists?
