Reply To: Hi – when I switched to EXR multi layer images, my alpha sockets disappeared from the 3 images. However, in the tutorial, …
Forum Archive Hi – when I switched to EXR multi layer images, my alpha sockets disappeared from the 3 images. However, in the tutorial, … Reply To: Hi – when I switched to EXR multi layer images, my alpha sockets disappeared from the 3 images. However, in the tutorial, …
#23406
Suchaaver Chahal
    I have a similar problem–a solution for some people is to use the “separate RGBA” node, and use the alpha from there. It doesn’t quite work for me, but it might for you.
