Reply To: Hi Kent, I'm using blender 2.75, how can I turn off project paint? I want the brush to stop at the UV seam, but the projec…
Forum Archive Hi Kent, I'm using blender 2.75, how can I turn off project paint? I want the brush to stop at the UV seam, but the projec… Reply To: Hi Kent, I'm using blender 2.75, how can I turn off project paint? I want the brush to stop at the UV seam, but the projec…
#23487
cyrax756
    With Blender 2.75, you can use face selection in order to paint certain areas only. Do this by enabling face selection which Kent uses to reveal a wire frame, however with blender 2.75 you have to select the faces which you wish to paint on which is why you have to have all faces selected to paint(Thus removing the desired wire frame effect that Kent demonstrates). By only selecting a certain area you can limit where you paint. Hope this helps.
