Reply To: Hi Jonathan Lampel, Some of the mirrored objects are moving in the opposite direction to what you expect during the animation, any thoughts as to why?
Forum Archive Hi Jonathan Lampel, Some of the mirrored objects are moving in the opposite direction to what you expect during the animation, any thoughts as to why? Reply To: Hi Jonathan Lampel, Some of the mirrored objects are moving in the opposite direction to what you expect during the animation, any thoughts as to why?
#28705
mechatronica
    Thanks Jonathan, yes that is “one” of the causes as well as the mirror modifier been applied to some of the objects causing them to move along in the same direction and another problem is that some of the parented objects are not moving at the same rate so when they move there drifting apart so Ctrl + J seemed to fix this drifting, although not sure whether  this is a good approach?
