Reply To: Hi Jonathan. Can you explain why using Decimate modifier would not be the great solution to lower the poly count? I know w…
Forum Archive Hi Jonathan. Can you explain why using Decimate modifier would not be the great solution to lower the poly count? I know w… Reply To: Hi Jonathan. Can you explain why using Decimate modifier would not be the great solution to lower the poly count? I know w…
#24119
bielus86
    Thanks. For me the main trouble after using decimate on complex objects is unwrapping.
