Reply To: Hi! I’m having trouble cutting the parts of my sculpture. The plasticine has cooled and the wire breaks. Thanks in advance. Google translator, sorry.
Forum Archive Hi! I’m having trouble cutting the parts of my sculpture. The plasticine has cooled and the wire breaks. Thanks in advance. Google translator, sorry. Reply To: Hi! I’m having trouble cutting the parts of my sculpture. The plasticine has cooled and the wire breaks. Thanks in advance. Google translator, sorry.
#26115
Lisa Schindler
    Hi Daniele!
    What you can try is heating a utility knife, or better some type of exacto knife, as these blades are usually pretty thin. I don’t know what kind of plasticine you are using, but usually they melt when exposed to heat, so a hot blade to cut up your sculpture could be the solution once it has cooled down.
    This is what I do when I need to cut (hard) Castilene or Cx5 once both materials have cooled down, because you can’t use a wire cutter with those two either.
