Reply To: Hi, I have used the script, which I called healthEffects, and applied it to two different objects (a sphere and a cylinder…
Forum Archive Hi, I have used the script, which I called healthEffects, and applied it to two different objects (a sphere and a cylinder… Reply To: Hi, I have used the script, which I called healthEffects, and applied it to two different objects (a sphere and a cylinder…
#23095
Nicholas Yang
    If you’ve applied the script on 2 separate objects, then they are keeping track of 2 separate health amounts, and the sphere seems to be winning out in the text display. You want both scripts to reference the same health value. One way to do this is to create an Empty game object “Health” with this script “HealthScript” to hold that health value:
    using System.Collections;
    using UnityEngine;
    public class HealthScript : MonoBehaviour {
        public int currentHealth = 50;
    And then adjust the pickup script:
    using UnityEngine;
    using UnityEngine.UI;
    public class PickupHealth : MonoBehaviour {
        public Text healthText;
        public int pickupAmount = 10;
        // Reference to HealthScript component in the Empty
        public HealthScript health;
        void Start() {
            healthText = GameObject.Find("Text").GetComponent();
            // Assuming that the Empty is named "Health"
            health = GameObject.Find("Health").GetComponent();
        void Update() {
            // Grab the health value from the HealthScript
            healthText.text = "Health: " + health.currentHealth;
        void OnTriggerEnter(Collider col) {
            if (col.gameObject.tag == "Player") {
                // Update the health value in the HealthScript
                health.currentHealth += pickupAmount;
