Reply To: Hi, I can do the painting in vertex setting/ object mode but can not render it. What am I missing?
Forum Archive Hi, I can do the painting in vertex setting/ object mode but can not render it. What am I missing? Reply To: Hi, I can do the painting in vertex setting/ object mode but can not render it. What am I missing?
#27224
Grant Wilk
    You’ll have to add an attribute node to your node tree and hook up the color output of that to the color input of your shader node. Then, change the name property of the attribute node to name set in the dynamic paint settings.
    Here’s an image from a similar process:
