Reply To: Hi, confused about boolean procedure
Forum Archive Hi, confused about boolean procedure Reply To: Hi, confused about boolean procedure
#96490
Sascha Feider
    Hi Shale @CookiePuss,
    not a problem, it’s part of the learning process.
    I don’t know how the ND addon handles the boolean operation, so I don’t have an answer to that.
    The bool tool menu however has two options:
    1. Auto Boolean – this performs the operation and applies the modifier right away.
    My guess is that’s what you used?
    2. Brush Boolean – this one adds the modifier to your object as expected and leaves your cutter object intact.
    This is the one you want to use.
