Forum Archive › Hey, I was going through your animation tutorial, and when I go to rotate the cube 180 degrees at 1 minute like it does in… › Reply To: Hey, I was going through your animation tutorial, and when I go to rotate the cube 180 degrees at 1 minute like it does in…
type in the values for rotation. First keyframe should be 0 then the second should be 360. Sometimes the keyframes use the same values so just double check that.
