In order to troubleshoot that better. I would perhaps recommend adding in a default cube and assigning it that material and putting each UV block of the cube on a color and see if it does the same thing. That may help lead you down the path of where the smearing is happening.
Almost seems as if your UV’s are sharing color space or similar.
