From the picture below you can see I have done that to test out the pointiness and it doesnt work. The white dots simply wont go. Trust me Ive been sitting on this now for 10 hours straight and tried it all. And I have followed all the steps from Kent multiple times. The first time this entire process worked perfectly fine but after I had made changes to my mesh I had to do the UVs again due to errors in the texture painting. I couldnt find a solution and I’m on a tight deadline. Is there a way that I can share the file privately with you guys to have a look? I would really appreciate it.
