Reply To: Help with Lava and Mixing Shaders
Forum Archive Help with Lava and Mixing Shaders Reply To: Help with Lava and Mixing Shaders
#75381
    Hi @neishy ,
    I’d need to see the complete Shader Node Tree, but your Mix Shader just uses a constant Factor to mix between Lava and Rock.
    You’d want to use a ‘Cracks Mask’ as the Factor, so the Mix Shader knows where to put Lava and where to put Rocks.
    Basically (and don’t use these exact Nodes, they are just to show how to use a ‘Mask’):
