Sure. Here is it: http://pasteall.org/blend/index.php?id=50157
And heres the map: http://pasteall.org/pic/8912c59626458ec791fe99f8f133c029
I have my problem in the barrels group with the barrelsup object. I also had problems with the barrelslow1 object which I already baked. I dont know if I did it right because I had to change the cage object in Edit mode in order to get the detail in the corners. Maybe you could take a quick look if I did it right?
Thank you very much!
