Reply To: Having trouble w/ frame rate independence
Forum Archive Having trouble w/ frame rate independence Reply To: Having trouble w/ frame rate independence
#84820
Sun-Jan Huang
    Hi thanks for taking a look at this:) I will follow your advice, although I did want to clarify one thing.  I have not been using the course files as I follow along, I only pulled it up as a reference to double check my work when I ran into this issue.  The video I uploaded is directly from the course file, if you download it and open the verlet collisions file, you should be able to reproduce the error. Thanks:)
