I’m not an expert at hard surface, but if I had to guess it would probably help to squeeze the circular topology inward, and make it so you have several strips of perfectly smooth polygons running down next to the sharp edges. Right now, the topology isn’t clean near the edges of the box which may cause problems.
But the others can probably get back to you with a more precise answer.
(Also hello fellow bird, I like your avatar)
