Reply To: Grid Fill creates slanted edge loops
Forum Archive Grid Fill creates slanted edge loops Reply To: Grid Fill creates slanted edge loops
#58578
Ingmar Franz
    According to the Blender 2.83 manual, in the case that you select the whole rim around the hole, the active vertex defines per default where the corner of the filled-in grid is located and the “Offset” allows you to rotate that corner.
