Reply To: Greace Pencil and Fill Draws considerations and questions
Forum Archive Greace Pencil and Fill Draws considerations and questions Reply To: Greace Pencil and Fill Draws considerations and questions
#28185
donbonbon
    Thanks for your answer.
    I have no problem with bugs and obstacles. But due to my limited knowledge, I struggle to distinguish between my limits and systematic ones, i.e. when to persist.
    Also, through the little contact I had while reporting bugs, I found a very dedicated developers unit and it feels great.
    The BG issue: herein the link that visualizes the problem with the BG. Though for me, it’s not a bug. Or else, I missed something about clamping.
    https://drive.google.com/open?id=1VSZXmp69hc_aprGx4waHx1ZgZd9Wftxn
    If the clamp acts as a mask it should consider what exists before it in the 3D space. When I place thus a BG, these points should be displayed, like when I place any other object mesh, etc’.
    Thus, I used world settings.
    In other words, my issue wasn’t why it appeared on my BG layer, but rather how it was displayed on your “magic” BG layer.
    Also, cleaning the boundaries strokes didn’t change anything for me.
    About the points/bouderies strokes – and the toothbrush analogy – I have no problem with banging my head against the wall, it’s my life story. Only that here, I note that I don’t really even have the illusion I might break the wall. It’s like being a relationship you don’t trust.
    At the moment it’s like I feel, I don’t trust the process, I cannot even visualize a process of making something out of it.  So I have questions.
    As the master of my learning, I ask if that will bring me somewhere…I cannot tell yes, thus, I need to take it into consideration.
    I need to improve my animation time production which comes with work and more work. Yet, if I compare the time ratio between Melvin hand and Melvin 3D lip sync is 10 to 1.  and the later end product is higher quality.
    I’m willing to bang my head against the wall, but currently, I ask if I should not be more humble and realistic and use older version that is more reliable. I just feel less confident I’m doing the right choice.
    Saying this brings to my mind… I traveled once with a guy that didn’t brush his teeth to make them rot and he could replace them with dentures.  Just another day and new choices to make;)
