Reply To: Grass particles weird result
Forum Archive Grass particles weird result Reply To: Grass particles weird result
#27805
Jonathan Lampel
    Ok, it looks like there’s two things going on here. First is that it’s super thick – to fix that try applying the scale (Ctrl+A) so that Blender knows how big the ground should be, or shrinking the root size if that doesn’t do the trick. Second is how it’s split up into different sections, which can be fixed if you change the hair primitive in the render properties from line to curve:
    Hope that helps!
