Hey @dirtnap ,
If you are using the start file it should be available, it is packed as part of the .blend, go to the texture properties with the hair object selected, scroll down a little and under image > settings you will see a file name greyed out, to the left of this there is a small icon like a file box, click this to unpack the files.
You could also create your own texture if you wish.
