Reply To: Good tool to create an inset into an already beveled surface?
Forum Archive Good tool to create an inset into an already beveled surface? Reply To: Good tool to create an inset into an already beveled surface?
#64668
abm3010
    you could use the Boolean modifier where you create the shape you want with a different object then use the Boolean modifier on the original object and select the new object as a target
