Reply To: GLSL show only a solid white texture on my low poly object. Normal map is baked and applied. If I switch to multitexture I…
Forum Archive GLSL show only a solid white texture on my low poly object. Normal map is baked and applied. If I switch to multitexture I… Reply To: GLSL show only a solid white texture on my low poly object. Normal map is baked and applied. If I switch to multitexture I…
#24941
dragonbyte
    Now I saved my image after I lost my normal map 🙂 thx.
