Reply To: Getting an array to follow a circular curve (wheel excercise)
Forum Archive Getting an array to follow a circular curve (wheel excercise) Reply To: Getting an array to follow a circular curve (wheel excercise)
#46493
    @raijkeraijke Yes, you’re right, that was a bit vague, to call it square-ish…What I meant, was, that from front view, the ‘lines’ should be horizontal and vertical, so the section is not tapered. So you need to select each straight ‘line’ and scale it along the X or Z axis to make it vertical or horizontal.
    This still sounds like a horrible explanation, but sometimes it can be hard to explain something just in text;)
    Anyway, I made your tire segment non-tapered and corrected the Bezier Circle, but you have some work left to do, for one, the tire is way to broad now….
    But here’s the file: https://www.dropbox.com/s/awfkmjovkz0j05e/WHEEL_corrected.blend?dl=0
